Import styles
Do you want to: Suggest a feature
Document Server version: 6.4.2
OS: Manjaro
Browser version: Firefox 95.0.2 (64 bits)
I created a template that allows standardizing the styles of documents when they are created. But if in two months I want to modify the style of all my documents (for example change the font and put the “Heading 1” in blue) I have to open all the documents one by one to modify the “Normal” and “Title 1” (via “Update from selection”).
Is it possible to have an “Import a style” function?
While waiting for this functionality, do you have an alternative solution?
Thanks
Hello @Drakone
We already thought about something similar (add the possibility to apply custom style to all documents). Unfortunately, I’m not ready to say when this feature will be ready. But we are working on it.
