Import data from different spreadsheet files
Hello @FrancoisM
v.12.5 is released for ‘cloud’ instances already. As for stand-alone Workspace (exe, docker, packages), we’re working hard to release it as soon as possible.
edit2: did a quick test on your online version, link will work during paste however every value will be filled with 0’s after update (either by menu>data>external links>update or after reloading the file)
Could you please reproduce the situation and make a videofile? Did you use Personal (https://personal.onlyoffice.com/) in your test?
@Alexandre, yes here it is https://transfert.free.fr/XGHC5N3 the link is valid 7 days.
Browser used Firefox 111 on Ubuntu 22.04.
I used mypseudo.onlyoffice.eu for my test.
Regards
edit: It seems to work after some times: if I go again on my 2nd spreadsheet it updated correctly, if I modify my first and update the second the modification are not copied yet but after a minute or so.
@FrancoisM
Thank you for the videofile! We’re checking the situation.
@FrancoisM
We’ve checked provided scenario, this is expected behavior (empty cells fill out with with 0’s). Additionally we checked out MS Excel, they have the same behavior.
One important thing about your recorded test, I believe it’s better to close\save first file. In your scenario you created a file, filled out a few cells and tried to copy to other file. At this step, when you tried to ‘update values’ on the new file, you have to be sure that the first file is already saved (it’s related to logic of work of Document server, the changes you have made to new file are located in the Document server cache\database, until you close\save the file).
Everything else seems to be ok, the feature works.
What’s the current feature implementation status for NextCloud plug-in?
Hello @EtagiBI
It’s recently added: https://github.com/ONLYOFFICE/onlyoffice-nextcloud/blob/master/CHANGELOG.md#added
  • Paste Special to add a link between files
