Do you want to: Report a bug
In ONLYOFFICE Presenations I’d like to achieve scrolling/switching/going to next/previous slide when you are zoomed in 90% or less. If you are zoomed 100% and more, you should be able to edit details of slide, so in this zoom state you should not be able to go to the next/previous slide. If you as user want, you could switch on/off this feature of possibility of going to neighbour slides ONLY if you are zoomed 90% and less.
For bug reports, provide the steps to reproduce and if possible a minimal demo of the problem.:
In 8.3.1.25 OO Presentation make new project with A4 Portrait format. Then add some details near the top or near the bottom of your slides. Then try to scroll comfortably without going to next or previous slide. You won’t be able to do this intuitevely. If this method of seeing and zooming to photos was applied to gallery apps on mobile phones it would be so frustrating.
OS version: Windows 11 Pro Version: 10.0.26100 Build.26100
App version: 8.3.1.25 I use ONLYOFFICE Presentations.
Downloaded from: ONLYOFFICE website. I downloaded Msi installer on 9th March From Official ONLYOFFICE website.
Additional information: Hi. In Powerpoint there is this issue too, but you can fix that by adding textbox hanging little bit above top border and under bottom border. In ONLYOFFICE you can do that too, but once you saved, closed and opened a file again, upper textboxes are adjusted to be places inside the borders. Soo, this “manual fix” in case of ONLYOFFICE does not work…
I use Portrait format. I saw other users also met this issue. I am not the only one that is frustrated by this issue.
Any relevant details about the situation. You can also attach images and videofile to the post (or to place them to external storage). : There is the video about this issue: ONLYOFFICE bug going to next slide ISSUE.mp4 - Google Drive
