Document Server version: 7.5.1.23
Connector version: 3.0.0
Attach logs if possible.
Since the last Humhub Update the JWT Version has changed, and they’ve changed header behavior in version 6.6.0 (2023-06-13).
So the Connector throws some errors like:
Error: Firebase\JWT\JWT::decode(): Argument #3 ($headers) cannot be passed by reference in /var/www/vhosts
I try to attache a diff file with all affected lines and necessary adjustments, but new user cant upload files:
diff -uNr onlyoffice_vorher/controllers/BackendController.php onlyoffice/controllers/BackendController.php
--- onlyoffice_vorher/controllers/BackendController.php 2023-11-14 22:04:28.020274860 +0100
+++ onlyoffice/controllers/BackendController.php 2023-11-11 22:48:37.000000000 +0100
@@ -21,6 +21,7 @@
use \humhub\components\Module;
use humhub\modules\file\libs\FileHelper;
use \Firebase\JWT\JWT;
+use Firebase\JWT\Key;
class BackendController extends Controller
@@ -91,7 +92,7 @@
try {
- $ds = JWT::decode($token, $this->module->getJwtSecret(), array('HS256'));
+ $ds = JWT::decode($token, new Key($this->module->getJwtSecret(), 'HS256'));
} catch (\Exception $ex) {
throw new HttpException(403, 'Invalid JWT signature');
@@ -116,7 +117,7 @@
try {
@@ -164,7 +165,7 @@
try {
$data = isset($ds->payload) ? (array)$ds->payload : (array)$ds;
diff -uNr onlyoffice_vorher/Module.php onlyoffice/Module.php
--- onlyoffice_vorher/Module.php 2023-11-14 22:04:27.988275602 +0100
+++ onlyoffice/Module.php 2023-11-11 22:57:54.000000000 +0100
@@ -21,6 +21,7 @@
use humhub\libs\CURLHelper;
* File Module
@@ -270,8 +271,8 @@
$headers = [];
$headers['Accept'] = 'application/json';
if ($this->isJwtEnabled()) {
- $data['token'] = JWT::encode($data, $this->getJwtSecret());
- $headers[$this->getHeader()] = 'Bearer ' . JWT::encode(['payload' => $data], $this->getJwtSecret());
+ $data['token'] = JWT::encode($data, $this->getJwtSecret(), 'HS256');
+ $headers[$this->getHeader()] = 'Bearer ' . JWT::encode(['payload' => $data], $this->getJwtSecret(), 'HS256');
$options = array(
@@ -342,8 +343,8 @@
$headers = [];
$options = [
@@ -396,7 +397,7 @@
$data['isEmpty'] = true;
- return JWT::encode($data, Yii::$app->settings->get('secret'));
+ return JWT::encode($data, Yii::$app->settings->get('secret'), 'HS256');
@@ -405,7 +406,7 @@
public function readHash($hash)
try {
- $data = JWT::decode($hash, Yii::$app->settings->get('secret'), array('HS256'));
+ $data = JWT::decode($hash, new Key(Yii::$app->settings->get('secret'), 'HS256'));
$error = 'Invalid hash ' . $ex->getMessage();
Yii::error($error);
diff -uNr onlyoffice_vorher/widgets/EditorWidget.php onlyoffice/widgets/EditorWidget.php
--- onlyoffice_vorher/widgets/EditorWidget.php 2023-11-14 22:04:27.980275786 +0100
+++ onlyoffice/widgets/EditorWidget.php 2023-11-11 22:36:38.000000000 +0100
@@ -205,7 +205,7 @@
if ($module->isJwtEnabled()) {
- $token = JWT::encode($config, $module->getJwtSecret());
+ $token = JWT::encode($config, $module->getJwtSecret(), 'HS256');
$config['token'] = $token;
