HTTPS fails
Do you want to: Suggest a featuI followed the guides to make my project work with https and everything went pretty well, except that now I have errors that I don’t understand. I am attaching a development console image.
Everything was perfect and now I’m getting two errors:
WebSocket connection to 'wss://-------------/7.1.1-23/doc/46/c/264/kegp1b1u/websocket' failed:
sdk-all-min.js:460 Mixed Content: The page at 'https://----------------/7.1.1-23/web-apps/apps/documenteditor /main/index.html?_dc…ustomer=ONLYOFFICE&frameEditorId=placeholder&parentOrigin=http://localhost' was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint 'http://------------- -/cache/files/46/Editor.bin/Editor.bin?md5=DeLph_iC0AV-pc-XctvVRg&expires=1717330634&filename=Editor.bin'. This request has been blocked; the content must be served over HTTPS.
Here is a screenshot
re / Report a bug / Ask a how-to question
Document Server version:
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well):
OS: Debian
Browser version: Chrome
Additional information: Everything is running on docker
Any relevant details about the situation. If you’ve modified configuration files or are using a proxy server that might affect the situation, please mention it. You can also attach images and videofile to the post (or to place them to external storage)
Hi @fedeamandi :wave:
Generally, this error means that a connection with a WebSocket has been closed due to a particular error.
However, it’s difficult to say what causes it by the screenshot you have provided.
  • Could you specify if you are proxying the requests within your network?
Have you used our instructions for using ONLYOFFICE Docs behind the proxy?
This error occurs when data is transferred from a service with HTTPS to a service with an HTTP connection. This is insecure and all browsers block this type of data transfer.
In most cases, this issue depends on the proxy settings and how you’ve configured your network.
It’s surprising that you’re using version 7.1.1. The current version of the document server is 8.0.1.
