Hi.
How can i reuse spreadsheet editor inside my plugin?
I want to use spreadsheet to manage data inside the plugin (like diagram editor does)
Hello @scoolnik
I’m not sure that I understand desired scenario right. Please provide us with details.
Do I understand the desired scenario right? - open a file > edit the file > run your plugin > new frame with editor opens.
Hello.
The desired scenario: open a file > open my plugin > enter some necessary data (using spreadsheet inside the plugin) > paste ole object.
As I said before, this is quite similar to how internal chart (diagram) editor works
We are checking the situation. I will update this thread when we have something to share.
Update:
We have checked provided scenario. Unfortunately, there’s no way to achieve your desired scenario at the moment.
We have added suggestion to internal tracksystem (internal number - 60249) to implement such scenario.
We have started working on it.
