How to use Mistral AI in ONLYOFFICE: a quick guide
Originally published at: How to use Mistral AI in ONLYOFFICE: a quick guide | ONLYOFFICE Blog
The updated AI plugin provides literally infinite integration capabilities allowing users to connect any AI model to the ONLYOFFICE editors. In this article, you will learn how to connect and use Mistral AI in ONLYOFFICE.
About Mistral AI
Mistral AI is an artificial intelligence startup based in France. It’s known for its open-source large language models, trained on a massive volume of text data. Like any other popular AI models, they can be used for all kinds of natural language processing tasks.
Since its establishment in 2023, Mistral AI has quickly become one of the world’s leading generative AI providers, offering a wide variety of general-purpose and specialized models that can be deployed on-premises or accessed in the cloud.
In this guide, we will explain how to use Mistral AI models in the ONLYOFFICE suite via a special plugin. Let’s dive into it!
Step 1: Install the AI plugin
You can skip this step if you already know how the AI plugin works in ONLYOFFICE and have it installed. However, if you have no experience in working with artificial intelligence in our editors, you need to install the AI plugin first, which is quite simple and straightforward.
Launch any ONLYOFFICE editor and access the Plugins tab. Open the Plugin Manager and find the AI plugin. Click the Install button.
After that, you should activate the AI plugin. To do so, click Background plugins on the Plugins tab. Now you need to enable the corresponding switcher for the AI plugin. If done correctly, you will see a new AI tab on the top toolbar.
Congratulations! Let’s proceed with the next step.
Step 2: Add a Mistral AI model
To get started with Mistral AI in ONLYOFFICE, you need to have a valid API key that you can generate in your Mistral account.
When you have one, go to the AI tab and click Settings. You will see the AI configuration window. This window allows you to choose various AI models for different tasks, such as translation and text analysis.
What you need to do now is to click the Edit AI models option in the lower right corner. This option lets you add new AI models. To add a new one, click Add.
After that, you will access the Add AI model menu. In this menu, select Mistral in the list of default AI providers, which also includes OpenAI, Together AI and Anthropic.
After selecting Mistral, you need to enter your API key in the corresponding field and click the Update models list button.
Now you can choose one of the available Mistral models depending on your subscription plan and the tasks you are going to perform with the AI assistant. For example, Codestral models are designed for effortless coding, and Pixtral models offer image understanding capabilities in addition to text. Learn more on the Mistral website.
Choose the required model and click OK.
Step 3: Configure the use of the Mistral model
Now that you have successfully added a Mistral AI model, it’s time to define the tasks you are going to perform with this model. Get back to the AI tab and open the Settings menu. In this menu, you can decide which models will be used for various tasks. This is very useful since you can add various Mistral models and even models from other AI providers.
The current version of the AI plugin has four options:
  • Ask AI is used to hold conversations with the chatbot;
  • Summarization is used when you need to summarize a large text in a few sentences;
  • Translation allows you to translate text from one language to another;
  • Text analysis is used to analyse words and explore their meaning.
Choose the desired models for each option. That’s it. The configuration process is over, and your Mistral AI assistant is ready for work.
Use Mistral AI to get your work done
Now that your AI assistant is properly configured, you can use it when working on your office documents. To access the AI assistant, you can use the options on the AI tab or the context menu if you select some text and right-click with your mouse.
Using Mistral AI in ONLYOFFICE, you can do different things:
  • Get precise answers to your questions;
  • Make various requests to the chatbot;
  • Quickly find information;
  • Analyse words and sentences;
  • Generate texts, images and keywords;
  • Summarize and translate texts;
  • Recognize text from pictures;
  • Explore the meaning of words and notions;
  • Write code and more.
Get the ONLYOFFICE editors for your Mistral AI assistant
Integrate any AI assistant and streamline your document workflows by creating a free ONLYOFFICE DocSpace account or downloading a free office suite for Windows, Linux and macOS:
START ONLINE GET DESKTOP APP
Useful links
AI plugin in ONLYOFFICE
Updated AI plugin: what’s new
Top AI tools for Office suites
How to connect LocalAI to ONLYOFFICE on Linux
Dear OnlyOffice Team,
Thanks a lot for your great work!
I was able to integrate AI models from Mistral an OpenAI using your AI plugin and the API keys for my corresponding accounts. However, this integration fails for Anthropic:
Anthropic
I’ve even tested my API key elsewhere. It’s valid and works. Also the plugin seems to recognize that the API key is actually working. If I “break” it intentionally by deleting some characters, the error message changes. However, even with the correct key it can’t load the model list. Unfortunately, the error message, which pops up when I hover over the little red exclamation mark, is not displayed completely.
Could you please help me out with possible next steps to fix this problem or confirm that it’s a bug?
Thanks a lot in advance and kind regards,
Markus
Hello @markusw
Please see this topic:
Dear Constantine,
Thank you very much for your quick reply. I’ve read the post. However, the step
… and select one of Anthropic’s models from the drop-down list. If you see no models, click the Update models list button.
is exactly, where the process breaks for me. Even though I’ve entered a valid API Key, the URL is the same as in your post an my internet connection is fine I can’t update the model list (error message).
Could you please check, if e.g. an update on the Anthropic’s side has broken the API connection for updating the model list?
As I mentioned above: The update function of the AI plugin works just fine for other provides. It seems to be only broken for Anthropic.
Thanks,
Markus
Please start a new topic with some additional information, I will gladly assist you on the faced issue. Make sure to specify following information too:
  • which product is used (ONLYOFFICE Docs, Desktop Editors, any cloud solutions);
  • version of the used product;
  • brief explanation of the faced problem.
Thank you.
Hello! How to recognize and generate images. These capabilities seem to be declared, but I can’t find them. What specific language model should I use for this? And where is this functionality. Please tell me the algorithm.
Hello @Buba
Please refer to this part of the article:
Thanks for the answer. I do have the Pixtral model connected, but I don’t see where in the OnlyOffice interface I can interact with it so that the model either recognizes text from a picture as stated or draws a picture. I tried to set such a task in Chatobot, but it didn’t work. There is no such menu item by right-clicking either. You kindly suggested that I learn more on the Mistal website. But I know how to interact with the Mistral chat and there is a different algorithm there. But the Mistral website does not say how to do this in the OnlyOffice interface. In this forum thread, you showed with pictures how to connect this or that Mistral model? But how do I set it a task so that it draws a picture or recognizes text. Where is such a button?
Please accept my apologies for inconvenience. I was informed that currently this functionality is disabled in the AI plugin, it will become available again in next version.
Hello! Thank you for the release of the new version of the plugin. I have already tried both text recognition in the image and image to text conversion. I have not yet been able to generate an image. Perhaps a different model is needed. I have the Pixtral model connected for everything. I cannot connect it to generate images. What model is needed for generation?
According to the latest information I have, all image related possibilities will fully become available with version 9.0 of the editor with new version of the plugin. Currently, new major release is not delivered, stay tuned for the updates.
