I want to make a PPT remote control plug-in. When I use StartSlideShow, it works normally. When I want to turn the page, I use GoToNextSlideInSlideShow and it doesn’t respond. Can you help me? Thank you very much.
Hello @yingshe,
We need the following details:
- What product are you using? Is it Onlyoffice Docs? What is the version?
- Please provide your plugin for test
- Screen reproduction of the issue
1.Onlyoffice Docs,The lastest 2. Just tell me more about GoToNextSlideInSlideShow, what does it do, and can it be used after StartSlideShow is called?,Thank you for your understanding
As it is described in the method documentation, it opens the next slide in a slideshow, it can be used after StartSlideShow. We would need to see your actual implementation to check on our side, maybe there is a bug
