Originally published at: How to update to ONLYOFFICE DocSpace v2.5 | ONLYOFFICE Blog
Following up the recent release of version 2.5 of the cloud-based ONLYOFFICE DocSpace, the self-hosted version of the document collaboration platform is already available. Now you can easily update your local DocSpace instance to get access to all the new features. Read this article to learn more.
ONLYOFFICE DocSpace v2.5: what’s new
If you update to the latest version of ONLYOFFICE DocSpace, you will be able to do the following:
- Share files and folders with external users via links;
- Connect third-party file storage platforms, such as Google Drive, OneDrive, Box, Dropbox, kDrive, Nextcloud, ownCloud, etc., to your public rooms;
- View, create and edit Markdown files;
- Create and manage user groups;
- Use presets to seamlessly embed their DocSpace or its part into any web interface;
- Import data from ONLYOFFICE Workspace, Google Workspace and Nextcloud;
- Set the default storage quota per room or per user to control disk memory consumption;
- Create multiple DocSpaces and make them accessible to your users.
Learn more about ONLYOFFICE DocSpace v2.5 in this article or watch the YouTube video below:
How to update your local DocSpace
If you have a running instance of ONLYOFFICE DocSpace Enterprise Edition other than version 2.5, you can easily update it to the latest version by changing the default false value of the -u parameter to true. This can be done with the following command:
bash docspace-enterprise-install.sh -u true
This command will consequently stop the required containers, remove them and then run the latest versions of the corresponding ONLYOFFICE DocSpace Enterprise components.
If you want to update only the DocSpace component without updating the others, you can execute this command:
bash docspace-enterprise-install.sh -u true -dsv v2.5.0 -idocs false -irbt false -irds false
In this command, the -dsv parameter refers to the DocSpace version.
Read this guide to learn more about the DocSpace components and how to update them correctly.
Deploy ONLYOFFICE DocSpace on your server
If you don’t have ONLYOFFICE DocSpace installed on your machine, you can deploy it by downloading the corresponding package for your Windows or Linux server from our website:
Useful links
How to install ONLYOFFICE DocSpace
How to update DocSpace: Enterprise Edition / Community Edition
