Error al intentar establecer la conexión (Se ha producido un error en el servicio de documentos: Error while downloading the document file to be converted.) (versión 7.0.1.37)
and Error al intentar establecer la conexión (Client error: GET http://192.168.0.150:32772/welcome/healthcheck
resulted in a 404 Not Found
response:
404 Not Found
404 Not Found
nginx
Hello @phsycko
First of all, please note that you are using outdated version 7.0.1.37 that is no longer supported. I’d recommend to update Document Server to actual version.
Are you trying to integrate Document Server with Nextcloud?
Please note that this is incorrect address for integration. You should use IP address only, e.g. http://192.168.0.150:32772
instead as the ONLYOFFICE Docs address in the connector settings. Try this out and provide a feedback.
Additionally, if you face any other issues please share version of Nextcloud or any other app you are trying to integrate Document Server with and version of the connector app.
