How to set viewer only read document but can edit comment?
i want set some viewer only read document(config.editorConfig.mode=‘view’),but cant crud comment.
for now,i tested:permissions.edit=true,permissions.comment=true,and editorConfig.mode=view,not working
On this page you can conveniently test setting different permissions and immediately see how it affects the Editor. All in all, it is impossible to comment in view mode
then it is impossible to can only crud comment in edit mode?
Yes, it is impossible
please tell me how to set it,thank you
There is no way to set it so that it is a view mode, but comments can be edited currently
