How to set value of checkbox content control as true or false.
I know how to do it in checkbox form but I am unable to find it using API for content control
Hi @arshaim39
It looks like you might want to use this method to set the checkbox value:
https://api.onlyoffice.com/docs/office-api/usage-api/text-document-api/ApiCheckBoxForm/Methods/SetChecked/
We’ve come across a similar challenge with checkboxes before in this thread:
https://forum.onlyoffice.com/t/the-radio-box-created-using-builderapi-could-not-be-selected/5187
Could you let me know if I’ve got your request right?
Thanks for your response
I know this method to check the checkbox but it just works in form not content control checkbox
I want to check the checkbox programitically using execute method but I don’t know which method it will take as first parameter
Basically I want to have checkboxes using content control and when someone select any checkbox, other checkboxes should unchecked just like how radio input works but all this I want using content control not using form methids
Is there any update?
Currently, we do have methods like AddContentControlCheckBox and ContentControlCheckBoxProperties
but as for dynamically unchecking other checkboxes when one is selected — similar to radio button behavior — I’m not sure if that’s fully supported at the moment.
Hey @arshaim39
Apologies for the long wait — only now we were able to take the time to review this.
We have created a bug report regarding the inability to change the state of a checkbox added via the API (SetChecked
Once this functionality is correctly implemented, we will update this post!
