ONLYOFFICE DocSpace 2.5 released: Public rooms improvements, user groups, storage management, embedding presets, and more
How to set a different default font?
For example: every time when i open a document or spreadsheet i want default font to be Verdana 10 point.
How this can be done? If this option is unavailable then please provide the same
I am on Mac OS Monterey version 12.7.
hi @MKVRC At the moment, there is no implemented function to change the document opening.
Version 7.5 adds the ability to create documents from a template
I will clarify about the possibility of opening a document with the necessary parameters directly from the main menu. (Implementation of document templates/tables/presentations in the main menu)
Hi Nikolas,
Thanks for the update, will wait to hear from you…
