Hi! Is there any way to select shape/slide from plugin?
As i can see, there is api funcs to select cells in spreadsheet editor, but is there an option to select a shape or a slide in presentation editor?
Hello @scoolnik
I am checking this, I’ll keep you posted.
Hello again @scoolnik
Sorry for the delayed response. From the plugin context you can utilize Select method of Api.Drawing
class via callCommand to select specific shapes.
Hi. Thanks!
Could you also tell me in which version this api was introduced?
Sorry, I do not have such info.
