OS version: win 10
App version: 8.2.2.22 (x64 exe)
Perhaps I just haven’t found the concept of global macros in documentation, or this is a feature suggestion. The result desired is to maintain a single copy of macro code, like custom function code, that can be accessed from other workbooks.
My current understanding is that if I want to use “Macro1” written in workbook A, that macro must be manually copied to all other workbooks where I’d like to use it.
Doesn’t this create a challenge to maintaining code? Am I missing the obvious?
A simple use case: User has hundreds of workbooks, each with non-contiguous ranges with a variety of “light green” fillcolors. User would like to apply a single “standard light green” fillcolor to target ranges in each of the workbooks, without having to copy the macro to each individual workbook.
[Edit] On further reflection, I’ll bet plugins might be the answer to ‘global’ macros.
