how to rename fileName ,i use word
Hello @zhengzetao
If you are using DocSpace and want to rename a file, then you have to right-click the file that you want to rename and click Rename option. After that a window will prompt to enter new file name.
If it is not what you are looking for, please elaborate on your request.
