How to modify the default font of docs
Hello
I’m using document server for centOS
Although I have installed some new fonts, every time I open dosc, the Arial font is still used by default.
I want to use a custom font every time I open dosc, as well as the default H1 ~H…
How to achieve this?
001
The font I want to replace
Hello @ebfming,
Empty file templates for every available language are located in the directory
/nextcloud/apps/onlyoffice/assets/
You can open a required template, set up the required formatting and save it.
hello
Do you mean to do this process once?
1、First configure the font I want
02
2、Save to the directory corresponding to the plug-in
3、but open a new document,that 's not my config font
03
thank you very much your help :hugs:
I’m successfully
