How to Merge Two Shapes
How to merge two shapes in OnlyOffice? We can merge two shapes by either Unioning, Combining, Fragmenting, Intersecting, or Subracting them in MS Powerpoint as shown in the screen-capture attached. Is there any way for us to the some similar things in OnlyOffice?
Hello @wky
Unfortunately, at present moment shape merge is unavailable in editors. However, suggestion to implement possibility to merge several shapes is registered and currently work is in progress. I am adding you query to existing suggestion and we will inform you when it becomes available.
Sorry for the inconvenience.
Hello again @wky
I’d like to inform you that in new version 8.3 you can now merge shapes. Please update Desktop Editors to the actual version and check out new functionality.
