How to know the cursor is in header/footer or document in plugin code?
Document Server version:
8.1.3
OS: win11
Browser version: chrome 133
Hello @softboy99
Please elaborate on your scenario, as headers and footers are parts of a document too, so I am not quite following why you’d like to know this.
Hi,
i want to drag and drop content and create mergefield to cursor postion in plugin, so we need to know it is in header,footer or content part
I’m afraid there no such method exists. You should not be able to drag and drop anything into a header/footer unless double-clicking it to edit.
Hi,
can we request the api for the future versions? Because when you insert something with your current api, it will need different codes in header & footer
I am not quite following your idea. As I mentioned, before even typing anything into a header/footer you need to open it at first, i.e. double-clicking header/footer from top or bottom part of the document respectively. Without it, you cannot practically drag’n’drop anything there. Once header/footer is opened, you can freely drag’n’drop your content into it.
Please elaborate.
