How to install plugin
Dear All,
After I clicked install, it looks like going to installation. However, I cannot see the plugin on the pannel. How to fix it?
Hello @ownzhao, what particular plugin are you referring to?
Dear DmitriiV,
I want to install the AI plugin. BTW, I cannot update or install any plugins also.
What is the OS on which the issue is reproduced?
Have you tried reinstalling the application itself?
I have the same issue: plugin manager pops up, kind of become unresponsive when I click “Install” (for any plugin), but the plugin never shows up in the plugin panel.
I’d like to install the OCR plugin, to no avail.
I tried to install many plugins, and the behavior is always the same.
I can’t “update” them, because they are not installed.
Tried to install/resintall ONLYOFFICE via winget and the official binary.
ONLYOFFICE latest desktop version available.
Windows 11 23H3
Could you please check if other plugin installation methods work? Adding plugins | ONLYOFFICE
If you’d be kind enough to procure the githuib pages or direct URL to plugins, I’ll try it, but it’s not that easy to find plugins URL…
