So I’m trying to insert a new row that exists in the context menu.
There’s my code
const ActiveCell = oWorksheet.GetActiveCell();
ActiveCell.Insert('down');
but it only adds a new single cell
There’s my code
For someone coming here with the same question I didn’t find a specific method, I’m doing like this (probably not the best solution):
const usedRange = oWorksheet.GetUsedRange();
const cols = usedRange.GetCols();
for (let i = 0; i < cols.Value[0].length; i++) {
console.log({ i, value: cols.Value[0][i] });
const rowRange = oWorksheet.GetRangeByNumber(activeCellRow, i);
rowRange.Insert('down');
Hello @Cursed
Unfortunately, there is no direct method for that as you noticed correctly. However, you can also use GetRows and Insert methods for this like that:
var oRange = oWorksheet.GetRange("1:1");
for (let i=1; i <= 1; i++) {
var oRows = oRange.GetRows(i);
oRows.Insert("down");
Here, GetRange("1:1")
specifies range above which new empty row will be inserted and i <= 1
amount of new rows. To my mind this example is quite easier to use because GetRange selects entire row for that matter.
