How to increment the cells value
Hi guys,
I’m trying to use the spreadsheet,
When I tried to drag the cells down, it give me the same value
11111
Is there a setting that I missed out ?
so whenever I drag down, the value is incremented.
I use this function in another software to help me to give id number,
so I don’t need to type for each row
OnlyOffice Desktop Editor
Version 7.5.1
Windows 10
edit:
I found the solution, after trying for an hour,
all I need to do press ctrl !!!
thanks guys, somebody can close this thread
Hello @ssilver23
We are glad to know that you’ve managed to find the solution by yourself. Good job!
