How to get doc content on every change?
const docInstance = getOnlyOfficeInstance("template_editor_renderer")
    const connector = createConnector(docInstance)
    connector.callCommand(() => {
      try {
        // Get the document instance
        const oDocument = Api.GetDocument()
      } catch (err) {
        console.log("Error in command execution - SS", err)
Hello @lovefrompal,
For us to be able to properly assist, we need you to provide a more detailed question.
Please elaborate on the scenario. What are you trying to achieve?
Hi @Carl On Form submit, I need to send document content as a HTML text
You can use this event Events and add your own function to it.
For example, you can try executing this GetFileHTML - ONLYOFFICE Api Documentation via connector when the event is fired. Please let me know if this helps.
Hi @Carl It Works. Is there a way to get the selected content as a html?
We have GetSelectedText mehtod and return selected content as a string
Yes, this is possible. Please take a look at this plugin example: Get and paste html
@Carl How do i get the selected content in html on the fly instead of getting it from box. Kindly share the code example of that
Hello @lovefrompal,
Unfortunately, at the moment it is possible only in the plugin. If you initialize the plugin with
"initDataType": "html",
"initOnSelectionChanged": true,
https://api.onlyoffice.com/docs/plugin-and-macros/structure/manifest/#variationsinitdatatype
you will receive selected parts of the document in html format in the init event.
https://api.onlyoffice.com/docs/plugin-and-macros/interacting-with-editors/methods/common-api/plugin/init/
We are planning to add the required method to the Automation API in Document Server 8.3 (~1 month).
Hello @lovefrompal,
In the latest Document Server 8.3.1 we have added the GetSelectedContent plugin method to get the selected content in HTML format. Example:
window.Asc.plugin.executeMethod("GetSelectedContent", [{
    type: "html"
}], function(result) {
    console.log("Selected HTML:", result);
Supported types are “html” and “text”. The API documentation will be updated shortly to include this new method.
