How to get bookmark name/id of current cursor
I need to get the bookmark(s) name or ids where the current cursor is at. Do we have a method or how can we traverse to get the closest bookmark.
Hello @agamdev
Unfortunately, there is no method to get the bookmark by cursor position. You can get all bookmarks in the document with GetAllBookmarksNames method.
@Alexandre Also i see we donot have any way to move to any particular bookmark like there is no method which we can use to move the cursor to any bookmark. This feature exists through UI when you open bookmark tab, it shows a list of bookmarks and option to go to that bookmark
Hello @agamdev
If you don’t mind, I will join this thread too.
We will check the described scenario (ā€˜any way to move to any particular bookmark like there is no method which we can use to move the cursor to any bookmark’). I will update this thread as soon as possible.
@Alexandre Actually i was able to use the method GetBookmarkRange and then call the Select method, however weirdly if i want to create a new bookmark with newly added text and i tried adding like in the example here
This issue is for newly added content
Hello @agamdev
We are still discussing the situation. I will contact you as soon as possible.
Hello @agamdev
Sorry for the late reply. Unfortunately, currently we don’t have desired method for moving to bookmark, and we decided to add it in the one of the next releases.
Thank you for bringing our attention to this situation!
Hello @Alexandre :slight_smile: , wanted to ask if this feature was added or somehow we can get the bookmark on current cursor.
Hello @agamdev
As it was mentioned earlier, there is no way to get the bookmark by cursor position.
However, if you want to go to specific bookmark in the document, you can use GoTo method. Here is an example:
let doc = Api.GetDocument();
let bookmark = doc.GetBookmark("bookmark");
bookmark.GoTo();
I am just a document user and don’t know how to use the programming commands. I do wish the bookmark function can be updated to automatically look up a bookmark in a passage which consists of more than 100 pages when we type a letter inside the box of ā€œBookmark nameā€. When we hit ā€œGo toā€ button, it will go to the correct position which was previously added a bookmark.
Hello @MegaEel
If you are not referring to the Docs API, then please start a new topic for your query. Make sure to provide the details of your goal and share some examples, if you have any.
In case it is related to the plugin/macro development, please refer to the following article on how to build plugins:
