Need dedicated support? Click here
Click here
How to fetch a document from OnlyOffice Document Server using document.key?
I have OnlyOffice Developer Edition installed on my server.
Now there are multiple documents as I can see in the already integrated “Test Example”.
Is there any way to fetch those documents or the latest/updated version of those document while the document is being edited/co-edited?
I want the latest copy of the doucments using API’s.
Kindly help me out.
Hey @Devyansh
Wait a sec
A “Test Example” is an example.
You can run the “example” to ensure its functionality and try out the editors in action.
You can learn more about documentserver and how it works by reviewing:
How it works
Hi @Nikolas ,
Thanks for answering. The links you provided have been a great help.
@Devyansh
You’re welcome :hugs:
Please do not hesitate asking questions if you have any.
