please find snapshots for more details…
select the shared excel sheet and then right click on any of the sheet an then select “select all sheets” option
then you will notice all the sheets are selected (as highlighted in below snapshot)
then select “hide” option to hide all the earlier selected sheets
then the reported error will popup
then when I try to unselect any one of the sheet all earlier selected sheets will get unselected! and have highlighted the same in below snapshot
question is how to unselect one sheet and hide all other sheets in one go?
so far I have seen this issue in MS excel, softmaaker office and onlyoffice…
hope with this you should be able to recreate the issue at your end.
should you need any more details then please let me know. Thanks
above snapshots are made using MS excel, but when you use onlyoffice the error message will be “Workbook must have at least one sheet visible”
