I just downloaded Onlyoffice for Mac to try as an alternative to Google Docs. It looks really promising, but I can’t figure out how to edit with continuous view. Right now, there’s a break between every page, like in print view/layout. I can’t find the setting to not edit in print layout. Help please?
Here’s an image of what I’m talking about:
Why can’t I get an answer to this simple question? This is so frustrating. This one thing is keeping me from using this otherwise great program. I can’t believe that no one else minds working on longer documents with these blank breaks between pages.
Hello @rwalker206
I believe you are referring to the feature that was discussed here:
Unfortunately, this enhancement is not implemented yet.
Thanks for the reply. It looks like that thread is over two years old, and this functionality is still not implemented. Hmm… Well, it’s a deal breaker for me. Bummer.
Just to be clear, it’s not just about removing that gray space. The View option I (and I’m sure many others) would like is akin to “Web” or “Draft” view in Microsoft Word, where you can write and write without any sort of page break.
I really want to use your program, but I simply can’t without this functionality.
