Hello!
Is it possible to create the table of contents of a document using DocumentBuilder API?
I mean this:
Thank you.
DocumentBuilder version: 7.1
Installation method: msi
OS: Windows
Hello!
I mean this:
Thank you.
OS: Windows
Hi,
Unfortunately, there are no such methods in the docbuilder API.
Hi,
Are you planning to add this feature?
We will discuss the possibility of adding this feature.
Thanks a lot for your quick reply. i will look forward for this feature
Best,
Anton.
We have registered an enhancement suggestion number 58561 in our internal tracker. We will inform you when the requested method is added to Document Builder.
Is there some information about this feature?
Thank you very much.
Hello @Anton
We are planning to implement this feature in upcoming version 7.3. Currently, estimated time of the release is first quarter of 2023.
