Hi,
I lost a lot of documents from Application Server:using onlyoffice API.
DocumentServer/cache is the only way to recover my documents.
How do I get documents from documentServer/cache(Editor.bin)?
Is there any API or Server Command with out ?
Hi,
Hello @grape
Could you tell what happened to the Document Server that you’ve lost those documents?
Was it unexpected server restart or some kind of error?
