Need dedicated support? Click here
Click here
How to config auth when setup document editor
hi, onlyoffice community, I am trying to integrate xwiki with onlyoffice doc.
config = {
        document: {
            fileType: 'docx',
            key: 'empty.docx',
            title: 'empty.docx',
            url: 'http://admin:#Fgglgy0223@172.25.161.211:8080/xwiki/bin/download/OnlyOffice/wordtest/WebHome/empty.docx?rev=1.1'
        editorConfig: {
            callbackUrl: 'http://172.25.161.211/example/track?filename=${DOC_NAME}&useraddress=172.30.7.4',
            customization: {
                autosave: false,
                chat: false,
                comments: false,
                forcesave: true
            lang: 'zh',
        height: '600px',
        documentType: 'word'
    var docEditor = new DocsAPI.DocEditor('onlyoffice-container', config)
the problem is I want the document editing service download attachment file directly from xwiki, but the attachment url need http basic auth, I tried embed username and password in url, but faild, I also find there is no option to specify auth headers.
please help
Hello Fanguogang.
Please note that we didn’t create XWiki connector:
https://store.xwiki.com/xwiki/bin/view/Extension/OnlyOfficeConnectorApplication
It was a developer team from XWiki.
As for auth access, please note that editors must have anonymous access to download files from the storage. Otherwise, please use JWT.
I find cookie is copied, so my problem is fixed, thanks.
@Alexandre need some detail about JWT token
My xwiki using openid-connect to authenticate user, so there is a JWT token in user’s session.
Can we use that token ?
Hello @Fanguogang
The main point is that Document server should be able to download a file without any authorization. If your usage scheme involves using authorization parameters (login to a storage to get a file), the Document Server will not be able to get a file.
If I misunderstood your request, please clarify it.
