Document Server version: 8
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well): Docker
OS: Rocky 9
Browser version:
Additional information:
Hello there, I’m trying to change API key for Thesaurus plugin. I found out that it should be called UserApiKey_Thesaurus, but I’m unable to find where and how it should be stored. Thanks for help.
