From github document server code, inside fileuploaderservice.js
Looks like the payload need key as docId, is there an example or document for this api ?
My usage is quite simple.
- upload file to FileUploader.ashx and get fileid
- use
<script type="text/javascript" src="http://localhost/web-apps/apps/api/documents/api.js"></script>
and config param to make a READ-ONLY viewer
Hello @shooding,
Unfortunately, we do not have API for this service. We recommend you to use available official guides. Please refer to this page to see how file opening works in ONLYOFFICE Docs:
https://api.onlyoffice.com/editors/open
On the next page you can check out the configuration of editors when it comes to different modes with examples:
https://api.onlyoffice.com/editors/try
