Do you want to: How to turn on allowPrivateIPAddress and allowMetaIPAddress for documentServer in docker.
DocumentBuilder version: 7.4.1
Installation method: Docker
OS: Mac
Hello @Harishkumar
Locate default.json config in /etc/onlyoffice/documentserver
inside the Docker container with Document Server first.
To connect to the container use command
docker exec -it [ID] bash
where[ID]
is the ID of Document Server container. To enlist all running containers usedocker ps
Then in the default.json config locate this section:
"request-filtering-agent" : {
"allowPrivateIPAddress": false,
"allowMetaIPAddress": false
Change values false
to true
like that to allow these parameters:
"allowPrivateIPAddress": true,
"allowMetaIPAddress": true
Restart Document Server services with supervisorctl restart all
to apply these changes.
