How to align a table to center?
hi, how to align a table to center of page?
Hello @Fanguogang !
You can adjust table properties using the right-click menu. Click the table settings icon > Show advanced settings. The Table Position tab is available only if the Flow table option on the Text Wrapping tab is selected. In the Table Position tab you will be able to set Horizontal and Vertical alignment of the table.
The detailed instruction you can find here.
got it, thanks! image
