akorn
16 September 2022 17:12
1
Is there a way to add keywords to an onlyoffice document?
The American’s with Disabilities Act requires documents to have the following for proper accessibility:
Title
Author
Subject
Keywords
Under document info I can add the title, author, and subject, but I don’t see the option for keywords?
Hello @akorn
There’s ‘Comment’ tab in the Document Info. Please let us know if it is suitable for you.
akorn
19 September 2022 15:11
3
The Comment tab does not insert keywords.
I am attaching a screenshot of what it should look like for proper accessiblity.
Can Onlyoffice add the keywords option?
Thank you for your description, we are checking the situation.
akorn
20 September 2022 19:49
5
Thank you. Please let me know if the keywords option can be added for proper accessiblity to those who are disabled.
Sure, I will update this thread when we have something to share.
Hello @akorn
We have checked described scenario and we added your enhancement to internal tracksystem (internal number - 59338).
We have started working on it.
