builder.CreateFile(“docx”);
oParagraph.AddText("This is a page with a footer. ");
oParagraph.AddText(“Scroll down the page to see it.”);
var oSection = oDocument.GetFinalSection();
var oFooter = oSection.GetFooter(“default”, true);
oParagraph = oFooter.GetElement(0);
oParagraph.AddText(“Here i need to add html content”); //Here
builder.SaveFile(“docx”, “GetFooter.docx”);
builder.CloseFile();
Unfortunately, Document Builder does not have methods to insert text as HTML. Insertion of HTML formatted text is available with plugin method PasteHtml.
UPD: We have registered an enhancement suggestion to implement methods to operate with HTML from Document Builder context similarly to mentioned plugin method.
PasteHtml is a plugin method and it cannot be used from DocBuilder context, i.e. from .docbuilder file. I’ve mentioned it only to show that there is an analogue to rely on for development of similar method for DocBuilder.
Hi @Constantine, thanks for your help. Is it possible to open another docx and insert it in the header and footer? I need an alternative to insert formatted content in these locations.
I’m not quite sure if I understand you correctly - do you mean that you want to get certain data from another document to insert it into another one? If so, GlobalVariable can be used, please see information about it here:
If I misunderstood you, please provide more details.
Hi, @Constantine I will explain my scenario to you.
Today in our system we use a simple html editor to edit our documents.
We record the header, body and footer information in separate fields in a table in our database.
We are migrating to Onlyoffice, for a better experience for our users.
The first time the user opens one of these already saved documents, I need to send it to onlyoffice (with header, footer and body) for the user to edit as needed.
After saving, we will not use the previous html data, only the docx.
I believe that this approach that you explained can solve it, I will test it.
Considering that you are planning to switch to using DOCX instead of HTML, you might want to try out converting your HTML documents into OOXML format. However, please elaborate on this:
This is correct documentation for conversion. In general, in terms of integration of Document Server with your own application you should take a look at Document Server’s How it works section too:
