Problem: I need arabic support for my application. As arabic is not currently available for onlyoffice.How can I add support for it?
Document Server version: 8.13.4
Installation method: Docker
OS: Ubuntu
Browser version: 112.0.5615.165 (Official Build) (64-bit)
We are actively working to improve all aspects of RTL support, including the Arabic language.
Could you please provide more details about the issue you’re experiencing?
8.0.0
- Add the interface translation into Serbian (sr-Latn-RS, Serbian (Latin, Serbia and Montenegro)) and Arabic (ar-SA, Arabic - Saudi Arabia)
- Add RTL support (beta) to the editors UI
8.0.1
- Fix position of diacritics when typing in Arabic
- Fix display of highlighting a comment added to RTL text
- Fix text label for Table of Contents in the RTL UI
- Fix an issue with shaping text with different direction (RTL and LTR)
- Added Arabic to all regional settings
- Improved work of the algorithm for displaying numbers and punctuation in Arabic text for the Neutral and Weak classes
- Improved fitting for paragraphs with main RTL direction
How do I change interface lang to arabic and enable rtl in documentcument server?
I found it in the documentations.
