I’m porting vba add-in to OO, but found that it is not possible to switch on or off data validation with list in OO using js. Is it true or it is my doc search fault? I’m try to port Selection.Validation.Add method
Hi @valdemar
As far as I can tell, there are currently no API methods available in the plugin system to work with data validation — such as creating or modifying drop-down lists — similar to Selection.Validation.Add
in VBA.
I’ll double-check this to make sure and get back to you with a more precise answer. Thanks for your question!
Hi @valdemar,
We already have a feature request in place for the [ApiBuilder] to add Data Validation support via builder methods.
Unfortunately, this capability isn’t available yet. We’re monitoring progress on the request and will keep you posted if it moves forward.
