How do I preserve indentation when replacing Content Control w/ Url or inserting image?
Hello, I have the following code
function example() {
  window.Asc.plugin.executeMethod(
    "GetAllContentControls",
    (returnValue) => {
      const docs = returnValue
        .filter((control) => control.Tag.startsWith(nestedPrefix))
        .flatMap((control) => {
          return [
              Props: {
                InternalId: control.InternalId,
              Url: "http://example.com/document.docx",
        .filter(Boolean)
      window.Asc.plugin.executeMethod("InsertAndReplaceContentControls", [
        docs,
When trying to replace existing content controls w/ the content of a URL, the indentation of the content control does not get preserved.
Screen Recording 2023-04-10 at 19.52.09 (1)
Is there a way to fix this / workaround this?
The same thing applies when inserting images with the following code:
function image() {
    [], (returnValue) => {
      const d = returnValue
        .filter((control) => control.Tag.startsWith(imagePrefix))
          const key = control.Tag.slice(img.length)
          const value = values[key]
          return [
              Props: {
              // language=JavaScript
              Script: `
                const oParagraph = Api.CreateParagraph();
                const drawing = Api.CreateImage("${value}", 60 * 36000, 35 * 36000);
                oParagraph.AddDrawing(drawing);
                Api.GetDocument().InsertContent([oParagraph], true, {KeepTextOnly: true}); // I've also tried `Api.GetDocument().InsertContent([oParagraph])`
                .replaceAll("\n", "")
                .trim(),
        .filter(Boolean)
        d,
Screen Recording 2023-04-10 at 20.06.47
Running Document Server 7.2.2
Hey @fr3fou
Thank you for the file and a GIF!
We are checking the situation.
I will let you know when I get something.
I tried reproducing the bug with 7.3.3, but it seems like calling CreateImage when using InsertAndReplaceContentControls like I’m using it doesn’t seem to be working –
Using the same code, results in the image looking like this:
This is a really sudden breaking change that prevents me from upgrading to 7.3.3 (still using 7.2.2) :confused:
This is a really weird.
Thank you. I will add information for testing the problem.
@fr3fou
We’re aware of the issue and have added the information to bug 44599 in our tracking system. The problem will be fixed in one of the upcoming releases, but unfortunately, I can’t provide you with an exact timeline at the moment.
After refreshing the page, the added image should display correctly.
Thanks for the quick reply,
Are we talking about the indentation bug for Url & Image replacements, images not rendering on 7.3.3 or both?
Hey, @fr3fou
Bug 44599 - Red cross instead of the image added to the content control using the InsertAndReplaceContentControls method.
Still working on this case.
