How can I create captions without enumeration?
In ONLYOFFICE Docs, I would like to add a caption to my images primarily for context, rather than for reference elsewhere in the text. In this situation, enumeration (i.e. Figure 1: something, or even just a. something) is unnecessary, and frankly a bit distracting. How do I disable enumerated captions entirely, so that I can simply make a normal caption?
Type of installation of the Document Server (docker, deb/rpm, exe): Flatpak
OS: Kubuntu 22.04.3 LTS
Hello @Domojestic
I’m not quite sure if it is meant to be disabled. Have you seen such possibility in any other document editor?
As a workaround: you can add Text Box under needed picture via Insert tab to place any text you want there as an alternative to caption.
