How can i change default styles on document editor?
Hello! I am studying plugins for the only office document editor. How can I remove the default styles and set my own? For all documents. I have my own set of styles that I want to display for all documents and for all users. Any option that will achieve the goal is suitable for me (plugins, apis, file replacement, etc.) I am using the document server comunity edition.
Hello @giome3c
Unfortunately, there’s no way to remove default styles at the moment. However, we are working on this feature already. I will update this thread once we implement it.
In the meantime, as an independent integrator, you still can change\replace templates that used in ‘Create New file’ scenario and add custom styles there. This way your users will create new file with you additional styles.
