Hope to provide Synology Drive plugin. 希望提供 Synology Drive 插件
Synology Drive 是一个非常优秀的共享存储管理工具;但是 Synology 自带的文档表格没有 ONLYOFFICE 更加的适合文档协作;他们是一个自有格式的文档,并且不支持一些高级的排版处理;如果能在 Synology Drive 中提供 ONLYOFFICE Docs 的插件,直接在 Drive 中调用 ONLYOFFCE Docs 那就太理想了!
Synology Drive is an excellent shared storage management tool; however, the built-in document spreadsheet from Synology is not as suitable for document collaboration as ONLYOFFICE. They use a proprietary document format and do not support some advanced typesetting features. It would be ideal if a plugin for ONLYOFFICE Docs could be provided in Synology Drive, allowing direct access to ONLYOFFICE Docs within Drive!
Hello @touma
Thank you for the suggestion and interest. We are indeed considering to develop a plugin for Synology. However, there is no ETA on the release of a connector app for it at the moment.
