Bug report:
OS version: Windows 11 Home
App version: ONLYOFFICE Desktop Editors version 7.1.1.57
The Spreadsheet do not display Hindi language text properly rendered in Cell. However it is correctly rendered in Formula Bar (when cell is selected for editing).
For Example: Following Hindi language text is properly rendered in the formula bar of spreadsheet as below
किस्मत से किसी की रोटी नहीं चलती, धन की कृपा भी जरूरी है.
But the same Hindi text is not rendered as it should be inside Cells. Hence the spreadsheet cannot be used for Hindi language.
Specially, Matras like (ि ी ु ू ृ ) are displayed at wrong location (i.e either after or below the character when it should be before or at slightly upper location).
