Hiding the toolbar on top the document
Currently, I’m using developer edition. Can i hide the toolbar in the red area by using DocsApi.
Hey @carl1 :wave:
If I understand correctly, this is what you are looking for:
You can also try applying these parameters directly on this page: Customization Settings.
Please review, and let me know if this meets your needs or if you have any further questions :saluting_face:
Thanks for providing that option. What about the status bar and 2 left and right panels, i wanna hide it by using settings
Hi @carl1 :wave:
I apologize for the delay in responding. Since you hold a license, you’re welcome to reach out directly to our support team at support for a quicker response to your inquiries.
Regarding hiding the toolbar, could you please clarify specifically what you would like to achieve? Any additional details will help us understand your needs more accurately.
You can also explore all available configuration options here: ONLYOFFICE API Customization Settings.
Thank you :hugs:
Why when I open the ONLYOFFICE links, can’t find
Hi @Eden :hugs:
We are continuously working on improving our API for better integration — thank you for bringing this to our attention!
The link you are looking for is:
https://api.onlyoffice.com/docs/docs-api/usage-api/config/editor/customization/customization-standard-branding/
Hello, I want to be able to open this screen
Unfortunately, the API is currently being transitioned, and at the moment, the ability to visually demonstrate parameter functionality is unavailable.
We are actively working on adding this feature back. Apologies for the inconvenience, and thank you for your patience!
In the meantime, you can use the following link:
https://legacy-api.onlyoffice.com/editors/config/editor/customization
This is an older version of the API, and it is no longer being updated. However, it still provides a way to visually explore parameter functionality for your needs.
