Google Drive integration?
I would like to connect my Google Drive storage with OnlyOffice local editor. I have been looking in OnlyOffice official documentation and I have found one post about this. However, I can’t follow “Connecting the Google Drive service” section, step 5, because I can’t enter access keys in any way (check screenshots bellow).
App version: 8.1.1.27
Downloaded from: Flatpak
Screenshots:
Hello @donete
Mentioned guide is used for Workspace, but from the screenshot I can see that you are using DocSpace. Please specify version of used DocSpace and installation type (Docker, DEB/PRM packages, MSI/EXE).
Thanks you for your answer.
First of all, I have to make a mention about my mistake. I have recently started with OnlyOffice, so forgive me. Where could I find a guide to my particular situation?
Secondly, like I wrote in the main post, I am working with 8.1.1.27 version and was installed from Flatpak.
This is about Desktop Editors, I got that. On the screenshot Desktop Editor is connected to DocSpace. Generally, before attempting to connect Google Docs, you have logged into DocSpace account so I am asking about that instance and its version besides Desktop Editors.
Let’s continue, I am so much busy this months.
How can I check DockSpace account version? Web browser and desktop editor are both ways to login in my DocSpace account. DockSpace account is not an application with a version code, so what do you mean?
I just found this: Imgur: The magic of the Internet
How do you access DocSpace via browser? Did you register DocSpace Cloud account and then connected the same instance in Desktop Editors? From the screenshot I assume that DocSpace Cloud is used.
Essentially, I’d like to understand if you are hosting DocSpace somewhere on your personal dedicated server or using Cloud version.
Yes, and I would like to connect my DocSpace Cloud instance or my OnlyOffice Editor with Google Drive. Is It possible?
Thanks for your time and your patience.
NOTE: I have got a free plan from DocSpace.
As per documentation:
In the SaaS version, some services are available for the paid Business plan only (Facebook, Amazon AWS S3, Google Cloud Storage, Rackspace Cloud Storage).
I’m afraid with your plan there is no way to connect third-party services to DocSpace Cloud.
