GetUsedRange macro function return empty range [bug]
Do you want to: Report a bug
  1. Fill in cells C3 and D4
  2. Run the macro
    Api.GetActiveSheet().GetUsedRange().Select();
  3. the range A1:D4 will be selected
  4. Delete the value in cell D4
  5. Run the macro
  6. The range A1:D4 will be selected instead of A1:C3
The expected behavior was similar to VBA function ActiveSheet.UsedRange - search for the last filled cell by columns and rows.
OS version: Win10 x64
App version: 8.1.1.27 (x64 exe)
Downloaded from: ONLYOFFICE website.
Hello @Rinzler
We will take closer look at this behavior. I’m keeping you posted about the results.
Thank you for reporting this issue. Bug was registered on this behavior, we are already working on it.
Sorry for inconvenience.
