Need dedicated support? Click here
Click here
Getting warning "The document could not be saved. Please check connection settings"
I am getting the below error while opening a document in OnlyOffice editor :
I checked the logs but there was nothing much other than this line which was repeated several times -
sendServerRequest returned an error: data = "{“error”:0}"
Kindly help me out and let me know how to get rid of this warning which prompts up every time I open the document.
I have read many related questions and none of them have worked for me yet.
hi @Devyansh
If you have valid license, then I’d recommend contacting us via Zendesk to get prompt replies:
https://onlyofficesupport.zendesk.com/
Are you trying to do integration?
Describe your situation in more detail.
Please specify the following information::
  • OS where your Document Server installed,
  • Type of installation (Docker, EXE, DEB/RPM)
  • Please send me the Log folder of the Document Server :
Linux: /var/log/onlyoffice/documentserver/
Windows: C:\Program Files\ONLYOFFICE\DocumentServer\Logs
Docker: inside the Document Server’ container: /var/log/onlyoffice/documentserver/ or on the host machine if it is mapped : /app/onlyoffice/DocumentServer/logs
  • Please send a screenshot of your browser’s console while opening any document via ONLYOFFICE editor:
"Open the spreadsheet editor => open developer tools in the browser (F12 in Chrome/Firefox) => refresh the page and make a screenshot that I can see Console and Network tabs.
