Do you want to: Report a bug
Calling from a plugin to the DocBuilder function “GetReviewReport” gives false positives changes when editing a document using the following permissions:
"permissions": {
"edit": false,
"review": true
To reproduce the problem, just type modifications and then do Undo (one or several times) or remove some of the reviews. So then you’ll have a list like the following
However, if I save the document and re open it, the “GetReviewReport” returns empty.
Best,
Document Server version: 7.4.1 web
Installation method:
OS: docker
Browser version: chrome
