We are currently doing a trial with an on-premise version of OnlyOffice using the WOPI Integration. Our Document Server is running the exe on a VM.
One of our required use cases is that our end users need to be able to edit multiple documents and create links between those documents. I know OnlyOffice has a hyperlink function but I’m unsure if there is an easy way for our users to link the documents via OnlyOffice URLs.
Has anyone successfully implemented a solution like this? As the linked documents are edited do those hyperlinks persist or are they broken as the document versions change?
