It’s not compatible with the Gboard spacebar movement gesture. It also doesn’t show word suggestions from Gboard for faster typing, and I feel like it needs a bit more fluidity.
OS: Android 13
Device : Poco X3 Pro
App version: 8.0.0
Hello @Benki
Please clarify your Gboard version and record a video file with your test. Did you run your test with local files or did you connect to cloud portal (Personal, Workspace)?
Hi,
1- Gboard version : 13.08.07.597073932
2- I use it for editing local files, sometimes I connect to cloud portals.
Hello @Benki
Thank you for the clarification. Could you please record a video file while you are reproducing the situation?
